anonymous
7060 points
Posted on - 02/22/2012
When I press “Install from Zip file”. is showing home folder, which is /var/mobile/ files, I can't find my computer files, it's not in the list,can't browse the computer to locate the navi-x file ,
Please help to solve this problem, it's very appreciated.
Cannot install navi-x on Apple tv
I'll give you here a way to install navi-x. download navi-x for xbmc from the navi-x website. Before installation you need to ssh into your atv and drop the navi-x zip file somewhere onto your atv which you can find it again by navigating to it when you choose the installation option "install from zip file". To install the navi-x from a zip file, go to the addons in the xbmc settings, then get more, keep clicking back until you see the "install from zip file" option. Navigate to where you dropped the navi-x zip file and select it and the installation should begin. If installed successfully, you will got a confirmation in the right bottom corner of the screen.
Hope this may help you.
Best of luck
Follow the steps below:
1. Download and install XBMC.
2. Download Navi-X. Place and leave the Zip file on the Desktop.
3. Launch XBMC and then go to System.
4. Choose Install from Zip and then Drive C: and go to Users and your User Account.
5. Go to Desktop and launch Navi-x.
6. Click Programs and choose Navi-x. And you are done.
You can watch the video below:
[video:http://www.youtube.com/watch?v=NSfGGHMaJHY autoplay:0]
