Can Nero software be installed on other partition?
Good day,
I have downloaded Nero software version 12 trial version. I can’t install this software because it gives an error that I don’t have enough space in drive C. Can someone guide me how can I install it in some other partition?
Thanks
Best Answer by Miguel M Burch
Answered By 20 points N/A #138804
Yes it can. When installing the program click on Custom Installation and designate your other drive. All programs can be installed on all and any partitions.
You might also want to run some cleaning programs to clean your Temp folders and the such. You'd be surprised how much space you can create just by doing that.
Answered By 50 points N/A #138805
Greetings! Your problem is quite simple and can be resolved easily. That error occurred because your drive C: is now almost full. To resolve this, simply change the destination folder of where Nero is installed. You have to choose 'Custom' or 'Custom Install' during the start of the setup so that you can change the drive letter to where it is supposed to be installed from C: to D: or E: depending what other available partition you have left.
