My phone is running Symbian OS and I love to have swf symbian wallpaper displayed on my phone. Recently, I got an error about any wallpaper not being able to display. My younger brother played with my phone before this happened. Did he uninstall something from my phone that have caused this issue?
Can no display swf Symbian wallpaper on my Phone
Hello Lindakcarico,
There are multiple possibilities that might have caused this to happen.
First of all, check your memory card, if its corrupted then obviously none of the files saved on it will run correctly. Get a new memory card in this case.
Secondly, you can try to run the same swf files on other phones with same Symbian platform, if these files don’t run on other phone then your phone is OK and these particular files may have been corrupted.
But in case, these files run on other Symbian phone, then there is definitely something wrong with your phone. Now you need to first reinstall phone software and if this does not work then there is definitely some hardware problem and you need to take your phone to the service center.
