I am doing some collage for pictures on Muzy.com and has completely typed the caption for it that is a bit long and has to do the same texts for my other clip board but I can not copy data from edit control and I have not saved the caption somewhere else. It gave an error saying internal server error occurred. I don't want to re-type the caption again since it is a bit long. Please help.
Can not copy data from edit control
The possible reasons why you can’t copy your caption is because the website internal error itself. I want to say that it is okay because technically, it is really not your fault that you have encountered this error. But the bad news is that you or all of us using any website with an internal error can’t do anything about it.
Internal error is literally an error on the web server that you're using. This error is possibly caused by misconfigured .htaccessfile. You have to wait for the website owner to deal with the problem.
