Cannot open my Samsung LED monitor
Hi. I recently bought a monitor and it is Samsung LED.
Now i have one problem with my computer.
When i start my computer my cpu can started byt my monitor can not start.
I check every cable of monitor and others.
I am purchasing brand new computer so Please tell why it can not start.
Best Answer by bethhenjov
Answered By 0 points N/A #113581
Hi. these issue due to the memory card problem,
Please check  and remove the memory card from the RAM slot then clean it by using eraser, after cleaning insert it back to the memory RAM slot.
Then Start the computer.
And its work.
NOTE:
If your computer is under warranty, bring it back to the store to fix the issue.
Thank you, hope its help
Regards;
Bethhenjov
Answered By 10 points N/A #113582
There can be many problems in your Computer only a technician can check it properly.
So you need to do is go to the shop you purchase the computer and ask him to fix the problem.
But you can also work on these points to solve your problem.
  • Check the monitor in another computer and make sure that fault is in your monitor.
  • Check for any cable that is unplugged. Also check the power supply and make sure it is available to your monitor.
  • Check for cable that is providing signals to your monitor and make sure it is working properly.
  • Check for any settings in your monitor and make sure that your power button is on. There can be more then one power buttons in a monitor so you need to find all and on them all.
  • Check that your CPU is working properly.
Once you go through these points you will be able to find external problem.
If your problem is not solved then you can contact a technician to solve your problem.
He can find the internal problem easily and will definitely solve your problem.
