Can not open PDF file.
I install Adobe Photoshop and Adobe illustrator. My one friend send me some documents by PDF format. I download this file and open. It show me a message and that is some file is missing and does not open.
So how can i open this file?
Best Answer by george.marquez
Answered By 0 points N/A #113571
Hello Mithun094,
It is expected that some PDF file is missing when downloaded on a computer. It usually happens if the Adobe Photoshop and or Adobe Illustrator is not updated. I have here steps as a back-up way to open missing PDF file. Disable View In Browser or Web Browser Integration feature in your Adobe Acrobat reader.
Here are the detailed steps; Open Adobe Acrobat Reader File, Preferences, General Uncheck Web Browser Integration Download again in the PDF file in your browser Open the file This should take care the problem of missing PDF file. Once open, you should be able to view the it using PDF.
Hope this helps.
