rae sax
Posted on - 06/06/2019
I keep getting “Can not place item: The workshop’s budget has been exceeded” when I try to place an item in my C.A.M.P. It doesn’t happen before and I can put any item I want. But few days ago, I started receiving this message. I have two tamed creatures that I want to put in my C.A.M.P.
Is there a way to fix this?
Can Not Place Item: The Workshop’s Budget Has Been Exceeded – Fallout 76
The recent February 19, 2019 patch now allows tamed creatures to no longer permanently consume C.A.M.P. budget after they are killed. If you keep receiving this message, scrap the items you previously placed in your C.A.M.P. or the items in your “stored” section until your budget is low enough to place the item. Your C.A.M.P. has space for a limited number of items only.
Once you’ve reached that limit, you will not be allowed to place additional items. The items in your “stored” section in build mode, even if they are not placed, will still count against your C.A.M.P. budget. When you move your C.A.M.P., the structures are bundled into blueprints which then appear in the “stored” category. These also count against your budget so you should try building those first.
