Rezvy
10 points
Posted on - 06/24/2011
 Hi
The problem is in my phone. My phone is Samsung sghm-620 model. I access internet in my phone using browser software . Now facing one problem, that is I setup opera 4.3 browser. Â When I use my front in medium size side , I can not see .
That why I can not access internet properly. Help needed.
jhonson
Opera browser not working Samsung phone
hi friend, opera mini does not work properly to your mobile phone because it can be installation problem. i think installation guide will be helpful for your problem. lets see how to install opera mini in your mobile phone,
follow this step. .
1. go to m.opera.com using your default phone web browser. then download opera mini.
2. After download install to your mobile phone. you can choose supported list form web site.Â
3. Then take exact mobile version opera mini for your mobile phone.
Also you can change the view of opera mini to your mobile phone.Â
then. go to Menu,
click setting and select mobile view
that will better display for your mobile phone.
thanks
