marfhux 0 points N/APosted on - 08/05/2011
My laptop is Gateway ec1433u
Specification
I search in Google:
1.3 GHz Intel Celeron 743 Processor
2048MB DDR2 667MHz Memory
250GB SATA Hard Drive
80211abgDraft-N Wi-Fi
116HD LED-backlit widescreen display
Intel Graphics Media Accelerator 4500MHD
Windows 7 Home Premium
Up to 6Hours of Battery Life
Product Description: Gateway Notebook comes with these EC1433u specs Intel Celeron Processor 743Windows 7 Home Premium 116 HD Widescreen LED-backlit Display Mobile Intel GS45 Express Chipset 2048MB DDR2667MHz Memory Intel Graphics Media Accelerator 4500MHD Whether its true VGA use 4500MHD
I check the Apron memory 797mb I try to play PES 2011 slow as hell. So if I can plan would replace the processor, Any processor suitable one for your laptop?
I was Googling this search results Celeron its socket 743 956
As far as I know, any Celeron related laptops are upgradeable while Intel atom’s processor is not upgradeable.
By the way, upgrade options of your laptop is available in your hardware manual. You may refer to your manual for the upgrade options of your laptop. We can tell you that your Gateway ec1433u laptop processor is upgradeable, but we can’t give you the specific process that your laptop’s motherboard capabilities.
Your 1.3 GHz Intel Celeron 743 Processor is compatible and supported in this technology:
Intel 64
SSSE3
SSE3
SSE2
SSE
MMX
Next to your 1.3 GHz Intel Celeron 743 Processor is the 763 which is 1.4 GHz. This was also supported on the above technology. So if your motherboard also supports the above listed technology this processor might be compatible with your laptop.
Why not to consider upgrading the memory? Your Gateway EC1443U laptop’s memory is upgradeable up to 4GB. The system has two slots available for PC2-5300 DDR2 667MHz memory. As what you have said your memory is just 2 GB and still you have available 1 slot for your memory adding one more 2 GB PC2-5300 DDR2 667MHz memory might speed up your computer or laptop processing.
2GB PC2-5300 DDR2 667 MHz memory modules is available on the market today which cost estimate is 38 US Dollars. You may find one on e-bay or look for other site by searching it on Google. This module might be also available in your local computer store. Just bring them your laptop or if you can bring just the memory module and show them what you want.
Unfortunately, it is not only your processor that’s below the requirements but also your video card. Before installing any game not only Pro Evolution Soccer, make sure your computer meets the requirements. Always check the system requirements of the game or application and compare it with your machine’s specifications. Your operating system is supported but falls short in the hardware part.
Pro Evolution Soccer 2011
Pro Evolution Soccer 2011 or PES 2011 supports Windows XP Service Pack 3, Windows Vista Service Pack 2, and Windows 7. It requires 2.4 GHz or faster Intel Pentium 4 or equivalent processor, 1 GB RAM, Microsoft DirectX 9.0c-compatible video card with 128 MB video RAM and Pixel Shader 3.0 support, 8 GB free space, and sound card.
If you want to upgrade the processor, check the supported socket of your motherboard. Use a processor with the same socket model but with a much faster speed.
1....
