Can ps2 convert to pc with online support?
Hi.
 I have converted ps2 games to pc using DVDs.
I want to know is it possible ps2 convert to PC online support without using DVD or any portable media?
Please give me a good solution.Â
Hi.
You have converted PS2 games into PC format. That is a good way to play PS2 games in PC.
But there is also a tool to play PlayStation games on PC.
For this work, you have to download ePSXe tool. You could easily play PlayStation games on Windows using this software.
If you would use this tool, you would have no trouble of converting.
With this tool you can't convert, but play games without any trouble easily.
Hello Bertharcummings,
I have been playing PlayStation games on my computer for a couple of years using PlayStation emulator.
Its called PSX emulator, you can download the emulator from here:Â There are easy steps to play a game on PC:
1. Download and Install the emulator
2. Open the emulator after installation
3. Insert your DVD CD into the CD rom. It will automatically detect it and will start the game immediately.
With this you don't have to convert the PS2 games to PC format as it is a lengthy procedure.
ThanksÂ
