Can Rhapsody Remote App be Played Using iPhone?
I currently discovered the rhapsody remote app and I'm wondering if this app can also be downloaded or installed in an Iphone or a tablet gadget?
Yes, there is also another application that let’s you access Music Services like Rhapsody™ and it is called iPeng. You can get access to the whole world of Internet Radio, access Music Services like Napster™ and Rhapsody™ and have control over them as if they were in your device’s own library, and access additional Squeezebox™ applications.
iPeng 1.6.1 supports iPhone, iPad, iPod touch and requires iOS 4.2 or later. iPeng costs $5.99. To download iPeng 1.6.1, you may visit Apple — iTunes Preview — iPeng. To download this on your computer, you need to install iTunes 10 for both Mac and PC.
Yes, I think Rhapsody can be downloaded on iPhone. It's compatible with iPhone and iPad. You can download this app from the link i am providing or you can directly download it from the app store. Rhapsody is a great app for browsing music online. Here's the link for download.
Hope this helps
Notifications
