Can some teach me how to maintain my PC performance?
Last month, My PC work fine, But this month My PC doesn't work fine. How can i maintain my PC performance?
I’ll tell you how you can make your PC perform well. First of all install new windows. Install Antivirus, NOD32 is the bit-defender and the best anti-virus among all I have tested yet. Your antivirus must be updated daily. Install tune-up utilities to clean your hard drive for useless temporary files.
Moreover you should check if your PC’s configuration is okay for the programs you are trying to run on it. Your PC should meet requirements of every program running on it. Usually PC should have enough RAM memory, so that It can be used for multiple programming at a time.
Always shut down your PC properly, power loss can cause damage in system registry, which is dangerous for software’s proper working.
Hope this helps!
Hi Jhone Vincent,
I hope this could help. Just follow my instruction.
1 – Write a maintenance assignment, Weekly, Daily and Monthly.
2 – For daily maintenance, do this, clean your computer, use a blower or a smooth paintbrush to wipe the dust and cobwebs inside your computer and on your output devices.
3 – Use a maintenance tools application that your computer has.
4 – Weekly maintenance, scan your computer using antivirus, ccleaner and tune up utilities. Clean your computer as your software cleaner recommended.
5 – Monthly maintenance, or weekly maintenance. Update your computer using "Windows Update" found on the start menu of your windows. To enhanced your PC performance.
6 – Install the updates that windows update recommended to you. Let your windows update download and install the application that your needs.
Good luck!
What you can do to maintain the performance of your PC are the following:
1. Download a registry cleaner. Registry cleaners help you delete values from your registry. Registry values from uninstalled programs are left behind. If these values build up, it can affect the performance of your PC. An example of a reliable registry cleaner is CC Cleaner. http://www.piriform.com/CCLEANER
2. Try to once in awhile clean the fans of your PC, because it absorbs dust easily. It may also affect the performance of your PC.
3. Delete unused files from your hard disk. The smaller the available disk space, the slower your PC will become. To me, this is one of the important things that you should do if you want to increase/maintain the performance of your PC.
4. If you are patient enough, try and use the disk defragment tool. It decreases the time for the disk to read a specific file. In short, increases the speed of your PC.
5.Avoid improper shutdown. Improper shutdown damages your hard disk. It leaves bad sectors and decreases the capacity of your hard disk space. This affects your PC's performance in a negative way. Bad sectors are not repairable.
6.Never forget to update your anti-virus. Viruses can significantly slow down your PC; it can even destroy your whole system.
To maintain your computer performance, follow the steps below:
1. Install a prominent antivirus software and then customize the schedule on when to run it.
2. Always backup your computer. Use the System Restore feature to schedule a backup.
3. Utilize the Windows Disk Cleanup to take the junk files out of your computer.
4. Always download the latest drivers, firmware and software updates.
5. Remove unnecessary or unwanted files and programs.
