Can somebody help me find ace image disk linux
Hi All,
I am using Linux Ubuntu. Want to have Ace Image Resizer for resizing, converting etc. Can somebody help me find ace image disk Linux Ubuntu?
Hi All,
There is no such application for Ubuntu. If you need to resize or convert your images then you can use the Nautilus Image Converter. It is a very handy tool since it integrates with Nautilus and you can convert or resize your image with two clicks.
To install it, open Terminal and type: sudo apt-get install nautilus-image-converter. When installation is done right click on your image and choose Resize image or Rotate image. Now you'll get dialog where you can find different options for your resizing or converting.
Notifications
