Can Someone Assist Me With 3d Display Mode Windows 10?
I had 3d display mode on my PC, and I don’t know how to use it. Please help using me with these 3d display mode windows 10?
To use 3d display mode windows, 10 use need to follow these steps:-
Step 1: In the control bar and click at the triangle placed near the symbol 3D mode. It will enable 3D display status by showing the 3D setting is ON.
Step 2: In the content type, select any option according to your preference.
Step 3: Now, switch on the option ‘2D to 3D conversion’ tick box to the 3D display mode.
Step 4: Now, on the ‘display type’ press on the ‘display monitor’ to choose the suitable display option and configuration.
Step 5: At the ‘Define Display’choose the perfect display option & configuration.
Step 6: Switch on the ‘set display panel size manually’ by pressing on the tick box. Then move the slider to set the size of the display hardware or monitor.
Step 7: After that press, the ‘OK’ button to save settings.
