Can someone guide about trace codes for text messages?
Hi
My question is that if i find some message from anonymous sender, is there any software that can provide me the trace codes for text messages?
Waiting for your reply
Answered By 0 points N/A #162020
You do have several ways to track an anonymous number. Please refer to the following facts.
* If you are getting the messages from an unknown number you can trace it through the support of your phone company. You'll have to get the support because only your phone company can track those totally restricted numbers.
* There is software that allows you to track any number globally. The service provider is "cellzio". They allow you to track numbers but the technology they are using is not much advanced, so that they can't trace the exact location. But it will give you the geographical boundaries with its tracking system. This service is not for free of charge. They charge you some dollars in order to provide their service.
https://cellzio.com/?gclid=CJ3e2fOg4LMCFQx76wodFQoAnQ
* Tracking a number needs access towards satellite data which means indirectly it's a huge task. All those free tracking software available on the internet won't provide you any help because most of them are simple applications which are created for simple purposes. If you really need help and if it is urgent the best thing is to contact your phone company.
