Hi. The hard drive of my Compaq C302 recently got corrupted. I had to boot an ISO image from a CD. Now, every time I start up the laptop, it performs a check disk. Can someone help me with boot ISO checkdisk? I'm on Windows XP 64 bit.
Can someone help me with boot iso checkdisk?
Hello, Dorindagmincey.Â
After finding a solution to your problem in checking disk when startup. I found some good solution and hopefully this will help you more. Try this simple step to skip from checking disk error on your startup. From "Start" click on "Run" then type "msconfig" (just ignore quotation). A dialog box will appear, then select  the startup tab. And when the check disk  has shown on the list , just uncheck the check box. I hope this can help you to fix you problem.Â
Best regards.Â
