Hallo people!
My Avira Ins registration has failed. I am having a genuine key which the application accepts and works for sometime without any issues. What I have noticed is that after 3 – 4 days, I get a message telling me that I have a trial version installed. If I input the key, it works fine for a while and then goes back to the same state. What could I be doing wrong with the Avira Ins Registration?
Can someone help me fix Avira Ins Registration?
There is a possibility of a corrupted installation regarding the problem or installing the wrong Avira package; in this case, installing the free version.
Make sure that you have downloaded the right version of Avira related to what package you purchased.
You will need to uninstall your current Avira first before you proceed to download and install the new Avira.
Here is the download link for various Avira packages (once again, make sure that you are to download the right package you have purchased):
https://www.avira.com/en/downloads
If the problem persists, you can contact support directly from Avira customer support. Here are the links.
For home packages: https://www.avira.com/en/support
For business packages: https://www.avira.com/en/support
Gibson
