strairt uas
5 points
Posted on - 04/03/2013
Hello guys. I'm a new user of InfoPath Designer 2010. I'm planning to create a shopping cart with SharePoint integration. Can someone here teach me how to make InfoPath shopping cart? I'm on Windows 7 64 bit. Thanks.
Can someone help me in making InfoPath shopping cart?
Hi Uas,
I am very glad to see that you are a new user of InfoPath Designer 2010. So you have to need lots of tutorial for InfoPath Designer 2010. I will give you the way how to make shopping cart with Infopath.
There are two parts to the form: 1 drop down box and the repeating tableÂ
The dropdown box has a list of part numbers. The table has fields for the part number, price, and manufacturer. All data is stored in Access db.
A) Â Select a specific number from the drop down box.
B)Â A rule is ran,
C) "Insert item" and chooses another product from the list.
D) Repeats this until you have added all the products you need.
Thanks for asking.
