Donna Davis
20 points
Posted on - 05/10/2013
Hello there. Can someone suggest or lend me an Office 2010 VBA indenter code? I would like my paragraphs in Microsoft Word 2010 indented automatically when I start a new paragraph. Any help would be much appreciated. Thanks in advance.
Can someone help me with Office 2010 VBA indenter?
Hi!
Every paragraph needs an indention in the first line, in Microsoft word 2010 there are some things you will do to make an automatic indention every time you're doing a paragraph or next paragraph you have to follow this easy step:
1. Right-click then select "Paragraph" and the dialog box for paragraph will appear.
2. In the "Indention", choose "First line" in the "Special"
3. Click "OK" button.
That is, your MS word 2010 has an auto indention every time you're doing a paragraph I hope this will help a lot.
