anonymous
7060 points
Posted on - 04/25/2013
The timing is completely awful, was working the next day couldn't access web, couldn't do a disk frag few days ago. I tried system restore w/ error 0x80042302, if I R click on cmd prompt it just runs 4ever so I can't run the sfc scan it says need admin priv,
Can someone please throw me a bone,
Hi Anonymous ;
Before running the sfc scan on cmd try to follow the steps given below :
1. Run Services.msc (by typing it on the Start menu search box)
2. Set Volume Shadow Copy and System Restore Service on automatic
3. Start System Restore Service
4. Reboot your computer
After these steps try running sfc scan on cmd.
Hello Anonymous,
If you want to clean your registry or other thing then you can use the software named as "CCleaner". It can help you in making your computer free from many of the things that are not necessary in your program execution. There is one other named as "PC cleaner" that can help you in making your computer free from many of the things which you are talking about. The link is below from where you can download that one and can use it.
https://pc-cleaner-pro-2013.en.softonic.com/
