Hallo Coders!
I am developing a Lottery system that I would like to use to determine the final winner in a competition. I have been struggling with codes and formulas to come up with something that is workable but it is no mean task. Where can I get spreadsheet Lottery formulas that I can borrow from to be able to accomplish this? Just a note; please share with me something that is not too complicated so that I can proceed the soonest possible. Thanks.
Can someone send me spreadsheet lottery formulas?
Hi Gustavojakee
To get lottery formulas with simplicity that will enable your system be workable without bias, I recommend you get a software called "Lottery Number Generator" This program offers a solution according to certain specifications. For instance a user can set the range of numbers to pick from (i.e.. 1-99) and how many picks to generate. It sounds easy i guess. Anyway there is a check box for sorting the results in numerical order or not. The winner(s) and the rest competitors can be saved as a list.
To get the software download, visit : http://lottery-number-generator-software.software.informer.com
