Hi there. Can someone suggest a DLL Suite similar software that I can use to identify and fix missing DLL files on my computer? I just installed the DLL Suite on my Windows XP 64 bit desktop but it always crashes. Any help would be much appreciated. Thanks in advance.
Can someone suggest a DLL Suite similar software for my XP?
There are many alternatives to "DLL Suite" such as "1-Click PC Care" and "DLL Repair Tool – RegCure".
But my personal favorite is "DLL-files Fixer", It allows you to run registry scans to fix System related errors, Com and ActiveX errors, User related errors and Startup and uninstall errors. It is also the easiest tool out there to install a specific DLL-File by name.
"DLL-files Fixer" is a safe tool because it allows you to Backup your registry before you proceed with any changes.
PS: Some DLL errors can be solved by installing or updating certain software: For instance, "D3DX9_43.dll" errors are related to DirectX, so you just need to install Its latest version.
In general, it is not recommended to download DLL files from other sources except if it is the only choice you can do to fix the problem. When your application triggers a DLL file missing error, the usual remedy is to uninstall and reinstall the program. The affected file is part of the program and it is being reported to be missing because the file is probably corrupt and can’t be opened.
That’s why when you uninstall and reinstall, the original file gets restored. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select the affected program among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If you haven’t updated yet, download the latest version. If this doesn’t fix the problem and the only possible remedy left is to download the missing DLL file, the most trusted site where I usually download DLL files is DLL-FILES.COM.
Once the DLL file is downloaded, unpack or extract the ZIP file and copy it to the installation folder of the program requesting it. If this doesn’t work, copy the DLL file to “C:\WINDOWS\system32” if the application is 32-bit and to “C:\Windows\SysWOW64” if it is 64-bit. This should fix the problem.
