I have a Canon PowerShot S110 12.1 Megapixel wifi capable digital camera that has the Digic 5 image processor. I would like to batch resize my JPEG images without compromising the EXIF data. Can someone suggest a freeware resize photos preserve EXIF software?
Can someone suggest a freeware resize photos preserve exif software?
Hi there,
You can batch resize your JPEG images without compromising EXIF data by downloading Picture Resizer. This is a freeware application. All you have to do is drag and drop the JPEG images or folder containing the images onto the application (picture resizer) and save them.
You can check this link for more tutorials- http://www.rw-designer.com/picture-resize
Hello Timothyy,
Preserve EXIF software and can resize your pictures easily is one of the function of Picture Resizer Software.
This software is easy to use just simply drag and drop JPG files or folders which has JPG files on the icon of the application. The tool will resize the JPG image and save them next to the originals.
Click the link below to download the Picture resizer.
The image link will give you an idea about Picture Resizer.
