emileekeila
Posted on - 05/12/2013
Hello there. Can someone suggest paid high quality CSS web login templates made specifically for 1024 x 768 screen resolution where I can also edit the background picture? Any help would be much appreciated. Thanks in advance.
Can someone suggest high quality web login templates?
Hi there Emileekeila,
With a little knowledge of CSS, HTMP and PHP you can easily change the background on every template where you have the access to the code.
Also, if you are looking only for a login form template, you will find them free or at really low cost and there is no need to pay much as the code is mostly all the same with just a little tweaks.
Best regards,
Drake Vivian
There are more than one site for web design styles or cascading style sheet (CSS), these sites help you to design suitable style for your own site, what I recommend you to use for this task is " Wix" website, it will help you to do what you want according to your choice and the following steps, it suggests a lot of templates for some categories of websites such as business, personal, design, service, retail, fashion and so on.
Select from categories and then start to create your pages not just login page because you will deal with complete website templates not individual pages, I think it will be powerful and helpful for you, it has wonderful, real and appropriate pages styles, you will view page and you can edit it as you want, it is possible to design the page and copy the editing code (CSS/ Html) and continue deigning by yourself. Go to this link
You will find easy steps that you follow.
This is the link where you can choose and download website log-in templates for free. Choose wisely and choose the styles that best suited your taste and style https://www.websitetemplatesonline.com/login.html. Just download the templates using your downloader.
