Can someone suggest a universal patch finder?
Hi guys.
I could not play some of my wav and aiff audio files on Microsoft .NET runtime.
Can someone here suggest a universal patch finder in 64 bit?
Any help would be much appreciated.
Hi guys.
Hi Paula,
Good day!! Thanks for question.
Universal Patch Finder by Hypercube Software’s: This software allows you to index any kind of.
Available in 64-bits and 32-bits windows.
I am providing a link please go to the link and download your expected soft.
Have a nice day. Best of luck.
Thanks
Any program that attempts to be "universal" tends to compromise performance for compatibility, hence a "universal patch finder" would probably not work very well. To fix the problem with not being able to listen to .aiff and .wav files, do the following:
1. Visit Online Audio Converter website by clicking here.
2. Select the desired category and audio format you wish to convert to in the left sidebar.
3. You will be brought to the page where you can upload your file.
Once the conversion finishes,you will be prompted to save the file.
Notifications
