Hi guys.
Where can I download the Digesec Hashing Utility software and how do I install it on a Windows Vista 64 bit system?
What algorithms would work on this program?
Can someone teach me how to use this software?
Can someone teach me how to use Digesec Hashing Utility?
Hi Dorindagmincey,
Digesec Hashing Utility is one of the best and easiest to use hashing utilities.
Now among the supported hashing algorithms are here:
•CRC32
•SHA-1
•RIPEMD-160
•ADLER32
•MD5
•RIPEMD-256
•WHIRLPOOL
•SHA-256
•TIGER
•SHA-512
You can download this program here http://www.planetalsh.com/download/Digesec_2.0.1.zip
This program is freeware and it a very small size program.
You will not have any problems with installing this program on any version of Windows system.
This utility program is meant for authenticating files that are most of the time offered for download on different websites using different hashing algorithms.
Digesec Hashing Utility is a free, easy-to-use hashing utility application. It creates the user selected checksum or digest of any text or file which, on the other hand, is useful in verifying the authenticity of the hash password, file, and many other security-related tasks.
The file’s checksum or hash can also be verified by just a click.
As of the moment, the program only supports these hashing algorithms:
CRC32
ADLER32
TIGER
RIPEMD-256
MD5
WHIRLPOOL
RIPEMD-160
SHA-1
SHA-256
SHA-512
Digesec Hashing Utility works on more than one or two hashing algorithms, and can automatically validate the file’s hashes or checksums. It also supports hashing of text copied to the clipboard as well as manually entered text. If you need to use it, you can download it. It supports all Microsoft Windows versions.
You may also watch “Digesec Hashing Utility: computer / engineering software – tutorial by TechyV”.
