Hi there!
I have some PDF documents containing information that I would like to upload on my website as pages. I find it a bit tedious converting the document to plain text and then doing the formatting again. What I would like to do is to carry out PDF conversion text html so that I can just upload directly and have all the formatting intact. Thanks big time.
Can someone tell me how to carry out PDF conversion text html?
Hi Halleleilani,
You can use PDF2HTML Online. This is a website that can convert your PDF file to HTML format and then save it as a zip.
You may access the site by clicking on the link below
https://www.thoughtco.com/pdf-to-html-conversion-tools-3469173
Then, you just click on Upload and select the PDF file you want to convert.
Once it is finished converting to HTML, it will give you a view of how the HTML looks like. It will match the format of the PDF file you uploaded.
After that, you just need to click on Download HTML. The file will be in a compressed form (.zip). You should be able to copy the files to a folder, open the html file using a text editor to view its source code and upload it to your website.Â
