Hallo TechGurus!
I was trying out Yandex bar on my Internet Explorer and I feel like I am done with it. I have tried severally to remove it but I cannot figure out where exactly I can do that. Can someone tell me how to remove Yandex bar in IE?
Hello Zimmerman,
The first thing that you are going to do is in menu bar go to the tools. Then, go to add-ons. After that, go to extensions and look for yandex bar and uninstall it. If this solution wont work try to go to the control panel and open add or remove programs, then try to look for the name yandex toolbar and uninstall it.
Hello Donnaz,
You can remove Yandex bar manually from Internet Explorer. You have to change few things. If you are using version 9 of internet explorer then select the gear icon, if not then click Manage Add-ons from Tools option. If you find any Yandex related entries then disable the option. If you are using windows XP then select Run from start and type ‘inetcpl.cpl’ in the open window. Now in the opened window select the Advanced tab and Reset respectively. For windows vista or windows 7 select windows logo and type inetcpl.cpl’ in the start search box, hit the enter option. After that same process, select Advanced tab then Reset. Hope this will help.
Good luck.
