Can SQ Anywhere log viewer access instant changes to a database?
10 points
Posted on - 05/01/2013
Hallo!
I have a database with a team updating data into the database continuously.
I would like to view the log so that I know what has been done and when.
This will enable to monitor how the team is working and whether they are conforming to the agreed terms.
Is the SQL Anywhere log viewer able to perform this task?
If yes, how does it work?
