ivonne Lara
Posted on - 05/04/2013
Suppose the record was accidentally deleted.
Then the records or data from database was deleted for several days.
Can sqlite deleted record recovery be recovers the data.
If yes how it is being done.
Can SQLite record recovery be useful for records deleted for several days
Hi Ivonne Lara,
Yes, there is an existing tool that will help you recover SQLite records, it is named, SQLite Record Recovery.
This tool can easily recover records such as table, views, columns, trigger, fields and etc.
It can also deal with the corrupted SQL .DB files from SQLite version 3.7 up to 3.7.7 Click here on how it will work.
Hello Ivonne
Yes you can recover lost data from sqlite. You only need the software and the instructions. And I will provide you with both.
First of all you must download and install ByClouder Database File Recovery. This is the link, just download and install it normally. BYclouder Database File Recovery.
After the installation is complete, open the software and press Start. Select the hard drive in which you had the lost database stored, check the box for .sqlite extension and press scan.
Every recovered data will be stored in a folder created by the program. It will tell you where the data is.
Another software which will help you recover the data is SQL Recovery.
Download it from the link ApexSQL Recover
I hope you will find this information useful.
Randolph
