Can’t change laptops display settings on Windows Vista
I am currently using my laptop computer which I have docked using a port replicator to my LCD TV.
The problem is that whenever I open the Display Properties dialog box and then click the Settings tab in Microsoft Windows Vista in order to change the display settings, I receive an error message as indicated below. How can I solve this?
Thanks in advance.
Invalid Display Settings
The currently selected graphics display driver cannot be used. It was written for a previous version of windows.
The system has been started using the default VGA driver.
Please contact your hardware manufacturer to get an upgraded driver or select one of the Microsoft provided drivers.
OK
