Can’t delete Alphabet Icon Pack from Windows 7
Hi, guys. I need your help!! I can't delete the Alphabet Icon Pack from Windows 7, Can anyone help me?
Dear Digital Solution
I have read your question and I understand that you need you have the alphabet icon pack for windows 7 and you can’t delete it.
Well although I wanted to know what happens exactly or what is the error message that you get when you try to delete the icon packs in order to help you more but I will tell you how to delete it:
1-Â Â Â Â You can delete it from the control panel
Click on start menu on windows 7
Click on control panel
Click on programs
Click on programs and features, and then uninstall a program
You will find the name of the program and then uninstall it and restart your computer
2-    If you can’t find the file in the control panel then you need to delete the file manually
Click on start menu
Click on computer
Click on local disk C
Click on program files and search for the program and open it, right mouse click on it and click delete
3-    If you can’t delete the file by right-clicking on it
Then you will have to download a program or a tool to delete it for you
You can download it Unlocker from this link
Download the latest version, or any download website that you know
Right mouse click on the file you need to delete then click on unlock chose, a message box will appear asking you what action you want to take click on delete and you will file or program will be deleted.
If this didn’t help you kindly send us the error message you are getting and we will be gladly to help you.
Best of Luck
