Can’t edit a file in COOL Webtop
Posted on - 06/24/2013
When I try to edit a file in COOL Webtop I get the following error message. I tried many times to resolve this error by searching but could not find the solution. I extremely need your help. Thanks.
The document name or path is not valid. Try these suggestions.
*Check the file permission for the document or drive.
*Use the File Open dialog box to locate the document.
(C:DocumentumCheckout3-04.doc)
