Can’t enable IE9 add on
I'm using IE9, but all the add-ons are disabled and I can't enable any of them. They are grayed out. I am using Windows 7 OS if this information helps.
Please help!
Please help!
To enable add-ons on your IE9:
If your add-ons are grayed out and you are unable to manage them, you may:
To manage add-ons further in your IE 9, you may check https://support.microsoft.com/en-us/products/windows.
Uninstall and re-install the internet explorer and ensure that the icon you are using to open IE9 is the “normal” icon. You will need to delete the icon and create a new one from the Program Menu; do not select the No Add-on. First, Right click the shortcut icon for IE9 on the desktop, the Click on Properties and select the Shortcut Tab, in case you see – extoff at the end of the path in the Target field, remove it. The IE9 usually has the developer toolbar pre-installed automatically however in some versions of the 32 bits it may be disabled in which case you will need to edit the key from the registry editor.
Normally, when you run Windows Internet Explorer in “No Add-ons” mode, you will still be able to access the “Manage Add-ons” option. Other users who encountered this problem have a problem accessing the “Manage Add-ons” option which sometimes is grayed out. There are times the “Manage Add-ons” option is accessible but the option to enable an add-on is grayed out.
Try creating a new user account and then run Windows Internet Explorer from there then check if the add-ons are grayed out. If you don’t see the problem on the new account, your user profile is probably corrupt. Here’s how to fix a corrupt user profile. Launch Windows Explorer then click “Tools” and then “Folder Options”. In “Folder Options”, select “View” tab.
Select “Show hidden files and folders” and uncheck “Hide protected operating system files (Recommended)” then click “OK”. Now, navigate to “C:\Documents and Settings\[corrupt username]” then select all files and folders except for these:
Press CTRL + C to copy. Next, navigate to “C:\Documents and Settings\[new username]” where “[new username]” is the new account you just created. Press CTRL + V to paste the files then select overwrite files when you are prompted. After this, restart your computer and log in using the new account you created. That should fix the problem.
On the other hand, if the problem still happens on the new account, try running Windows Internet Explorer as administrator. One user was able to fix it using this method. Right-click Windows Internet Explorer then select “Run as administrator”. If this works, you need to change the program’s compatibility to always run as administrator. Right-click Windows Internet Explorer then select “Properties”.
Select “Compatibility” tab then under “Privilege Level”, check “Run this program as an administrator” then click “OK”. That should fix it.
