Can’t export projects over 45min long in Adobe Media Encoder
I am using new MC6.01 and it’s very fast and simple to use. But the problem comes when I finish editing lengthy video projects. I have included the snap of that message. Normally I will export the output to DNxHD quicktimes because I feel that the reader is quicker than Adobe Media Encoder or Hand-brake then I will do final encoding
What does this error mean?
Exception: std: exception, what:Error c0000005 in Thread "CqTEExportWorkingThreadBody",ACCESS_VIOLATION, at address 000007FEEE64BFB9
My PC configuration is 3DBOXX 8400, Quadro FX570 (driver 275.89), Dual XEON 5420, 12GB ECC DDR2 FBD RAM, WACOM Antennas' 2, Windows 7 Ultimate SP1, Avid Media Composer 6.0
