Hello everyone,Â
 I am using Acer laptop. I upgraded my operating system from XP to Windows 7. All the drivers are installed, but signal up wireless driver windows 7 is not installed. I can't find the driver, please help me.
Thanks.Â
Can’t find signal up wireless driver in windows 7
It was necessary to download all drivers before your installation windows 7. But now you should download the driver from the Acer’s official website. Just go to the website select your Location and after selecting your location another window will be open. Follow this instruction Driver Downloads> select a product category> product family> product line> product model > supported OS and choose wireless  driver to download. Then try to install this I think it will be work.
Best of luck
