Can’t find an way for double click and opening excels files
This problem has driven me crazy over the eon. I have 2 monitors and I like to keep 2 different excel windows open. The problem is that I can’t find an easy way for double click and opening excels files in 2 separate windows. Each time I give double click on an excel file and it opens on the current excel window. I installed excel 2010 with a hope that the behavior would change but no, it didn’t.  It’s the same as excel 2003 and excel 2007. All excel files open in the same Excel Window, which drive me crazy. Only solution I can find is opening up 2 windows then doing the old fashioned File Open. Can anyone please, help me to do it?
