Can’t Get Vista to Run in VMWare Fusion 4
I just switched from Windows to Mac and downloaded VMWare Fusion so that I can get to run Windows software even if I'm using Mac. The problem is, I cannot get it to work. I have migrated images several times but when I start it up, I get a blue screen then when I use Safe Mode, Windows says it cannot fix the problem. What can I do to run my Windows Vista to VMWare Fusion?
