Can’t Install LoadUI-Unable to import the application
Hello everyone, I am having this problem whenever I try to install LoadUI. The following error message shows:
As per the error message that you are getting while installing the LoadUI. Its not able to import the files. It could be happening because of corrupt files. Or it could be due to release of LoadUI newer version in the market. Solution for this issue is simple reinstall the software or You can check for any new update or change of version. Whenever you get such messages simply reinstall the software or look for new version more often than not,it solve you problem.
I'm sending you a link from where you can get relevant information.
https://smartbear.com/product/ready-api/loadui/overview/
Thanks
