Can’t Install .Net framework 4.0
Hi, I am having problem in .Net Framework installation in my vista operating system. After downloading the components, when trying to install, it fails with a message ERROR 1603. I tried with some previous versions but nothing seemed to be fixed. Please provide me some solution for this problem. Thanks.
Answered By 15 points N/A #90159
Here following the solution for you :
  • At first click on “Start” button
  • Then select “Control Panel”
  • Now select “Programs and features”
  • Then Search for .NET Framework 4 in program list
  • And then Select it (NET Framework 4)
  • Select on REMOVE OR CHANGE
  • Now follow the steps which are display and select the Repair option (not Remove /uninstall ).
  • When the repair is done, then restart the computer and then try to install the updates.
I hope your problem will solve, but if it does not solve then select “Start” button
Then select “Control Panel” now select “windows update” and then right click on .NET Framework and copy the details and paste it in you browser search option. Let you download it manually. After complete download install it in your computer.
I hope your problem will solve.
