I have got the following error message while installing the Nokia Suite using Windows 7 Operating System. The error shows “An error occurred during the installation of assembly”. Please help me with full information. Any help would be greatly appreciated.
Thanks in advance.
Something’s gone wrong
An error occurred during the installation of assembly ‘Microsoft.VC90.MFC, Version=”9.0.30729.4148”, publicKeyToken=”1fc8b9a1e18e3b”, processorArchitacture=”x86”, type=”win32”. Please refer to Help and Support for more information.
Can’t Install Nokia Suite – Error Message (Windows 7):
Hi Joseph,
The error is because windows 7 was unable to install assembly files.
There are multiple solutions to resolve this error.
Solution 1: Empty all the temporary files present in the system.
1) Click 'Start', Click 'Run'
2) Type 'temp' in the run prompt
3) After executing the command, temp folder will open
4) Select all the files, delete them
5) Close the folder
Solution 2: Install the application in clean boot mode
1) Log on the system as Administrator
2) Click 'Start', type 'msconfig.exe', press enter
3) In the General tab, click 'Selective startup' option, Uncheck 'Load Startup items'
4) On the 'Services' tab, Select 'Hide all Microsoft services'
5) Click 'Disable All'button
6) Click 'OK', Click 'Restart'
7) The system will restart
