Can’t Install Sony Xperia S Update
I can't install the latest update of my Sony Xperia S which is the ICS 4.0.4. I normally can install updates flawlessly but now my phone is not updating successfully. What can be my problem?
Dear,
It seems that your phone update process has some error. If mobile phone fails to update perfectly then it may not run. In that case you need to reinstall phone BIOS. For better update process connect you phone with a computer that has internet connection. Phone pc suite also required for update process. Computer saves a backup while you update your phone using computer.
Thank You.
Hi Karrie,
Before updating your phone make sure that you have chosen “Enable USB Debugging” found under Settings> Applications> Development. This makes the throughput from the computer to your device possible. Make sure that your phone is charged to 70% or more since updating may take sometime abrupt shutdown of the device will cause data loss. You have to disable Security tools and Antivirus software both on the device and the computer. All these small details might be forgotten prior to updating.
Hi, Karrie.
In updating your Sony xperia S, you need to switched off your mobile phone before you start connecting to the software that you use to update you phone. You can download the latest software here https://support.sonymobile.com/global-en/xperia-companion/ . Make sure you uninstall the old software before you install this one. Hope this advice will help you .
Best regards.
You can download the Sony Update service in order to have no connection interruption or software interruption on updating the product. You must also have these things as prerequisite in order for you to continue:
After checking the prerequisite, I advice you to go here: http://software.sonymobile.com/emma/install_packs/Update_Service_Setup-2.13.7.201306141231.exe. It is the setup application link that goes with your application in order for you to go and update the mobile phone. A set of instruction will appear on the said application, follow the steps at your ease.
The Sony Xperia S is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on January 2012 and released on February 2012 measuring 128 x 64 x 10.6 millimeters and weighing 144 grams. It uses micro-SIM card and has LED-backlit LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
It supports multi-touch up to ten fingers protected by scratch-resistant glass. It runs on Android 2.3 Gingerbread upgradable to Android 4.1.2 Jelly Bean powered by Qualcomm MSM8260 Snapdragon S3 chipset, 1.5 GHz Dual-Core Scorpion processor, and Adreno 220 GPU. It doesn’t support microSD. It runs on 1 GB RAM with 32 GB internal storage.
The primary camera supports 12 megapixels with LED flash and autofocus featuring face and smile detection, panorama, geo-tagging, and touch focus. It supports 1080p video recording at 30 fps. The secondary camera supports 1.3 megapixels and supports 720p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS and GLONASS support, NFC, stereo FM radio with RDS support, and microUSB 2.0 with USB Host support. It has built-in compass, proximity, accelerometer, and gyro sensors. The pre-installed web browser supports HTML5 with Adobe Flash support.
Java is supported via Java MIDP emulator. It runs on non-removable Li-Ion 1750 mAh battery with standby time up to 450 hours on 2G and 420 hours on 3G. Talk time is up to 7 hours 30 minutes on 2G and 8 hours 30 minutes on 3G. It is available in black, white, and silver colors.
