Can’t re-install Nero 7 on Windows 7
I currently work in an IT department in an education facility in which we run Nero 7(with a license). One of the educators had Nero on her machine but she was having problems so I formatted her PC and did a clean install of Windows 7 (32bit) and am re-installing all of the programs, as far as I am aware Nero worked before.
The problem arises about 75% through the installation when I get the following message. I know it is not the disc or the program because I have installed it before on numerous machines without a hitch.
According to the windows log file it is either msiexec.exe or NMTVservices.dll
I have tried installing it lots of times but the same error always occurs.
Some of the message boards suggested I run as administrator which makes no difference. The program has all the necessary license right. Other posts suggested it might be conflicting with K-Lite coded pack but that is not installed.
Even the Nero General Clean Tool crashed! I just get an error message saying "Nero Clean Tool has stopped working." After rebooting I got the following message a bunch of times:
Fatal Error:
Installation corrupted – please reinstall NERO
OK
We desperately need this to work, any ideas what is going on here?
I know that Nero 7 is no longer officially supported but we have a campus license so for better or worse we are stuck with it!
