Can’t Remote Web Access of the second SBS 2011 Essentials server
 Hello there! I cannot open the Remote Web Access of the second SBS 2011 Essentials server which I tried to install. It shows the following error reports “Server Error in ‘/’ Application” coupled with several details about the problem. So far I have manually configured my router and have properly forwarded ports 443 and 80 to the server. However, the problem won’t go away. Can someone shed some light on this issue and help me figure it out?
Answered By 0 points N/A #154639
This might be due to the insufficient resources or rights you have. Precede the following steps to make sure you have the right things to do it.
  1. First of all, make sure that you are logged in as admin of the system. Then run the application.
  2. If you are not the admin, then first log in as admin. If there is another admin of the system, do ask it for the required rights to allocate it to you.
  3. After that close the application and re run the application after restarting and logging in the account again.
  4. After that, check if the ports re being blocked by a firewall or something that can cause the connection to interrupt.
