Can’t remove television fanatic on Firefox 13
Here is my very first question.  I need help!   O.S.: Ubuntu 12.04.   Browser: Firefox 13.
Foolishly I tried to download televisionfanatic without first checking about it on the web.  It did not download but, every time I go to 'add-ons manager' and click on REMOVE, the 'add-ons' reappears even though it shows as 'disabled'.  The computer does not seem to have picked up any problems and works just the way it did before I attempted the download.
Best Answer by Davis Karrie
Answered By 0 points N/A #161893
Dear User,
You can easily remove Mozilla Firefox from you system and reinstall it. Because when you do that, all the add-ons will be removed too.
In order to do this you can simply go to ubuntu Software Center and select Firefox and uninstall it.
Same way you can re install the Firefox.
Thank you.
Answered By 0 points N/A #161894
Hi, Roadie
If you need download the program.You have need do this that,
1. Firstly you need remove your browser.
2. Secondly you need download any browser.
3. Then you need install the program.
4.Then you have do this that, open the browser and search the program and then download the program.
I hope your problem has been solved.
