Can’t run macro on Solidworks 2012 SP1
Hello people
I am using the 3D cad software Solidworks 2012. When I run a macro on SW 2011 SP4 it runs perfectly but I am facing a problem when I try to run a macro on SW2012 SP1. I am met with an error every time. The screenshot of the error is attached below:
![](https://www.techyv.com/sites/default/filesx/users/zakaria/SW-2012-macro-error.jpg)
Microsoft Visual Basic
Object library invalid or contains references to object definitions that I could not be found
OK Help
I also tried my adding a reference before running the 2012 version as you can see in the following screenshot:
![](https://www.techyv.com/sites/default/filesx/users/zakaria/SW-2012-macro-error-image-2.jpg)
But still the same error persists.
Any help will be highly appreciated.
Waiting for your suggestions
Regards
