Good day! I’ve recently downloaded ms access free membership database to my computer and it failed to operate. My cousin told me to adjust settings for security but it didn’t work out. It works well on the other laptop though but on my PC it doesn’t.
Can’t run ms access free membership data base on PC
Hence you use free membership database of Microsoft access so some time it create some problem like can’t run or not open the access file.
In this situation you need uninstall the previous Microsoft access from your computer.
Now reboot the computer.
After start the computer scan your computer by the antivirus and install the Microsoft access.
I think it will be work.
Thanks
May be your computer is infected by some sort of viruses. At first you check that out.
If there is no virus on your computer then you can try by reinstalling the ms access of your computer.
I think your problem will be solved.
thank you
