Can’t see my device data in Google Drive
I have an Android device which is configured with two Google accounts that I mainly use to backup my data. I am not able to see the data in Google drive and I also can't see contacts from Gmail. Where do they back up all the data?
Answered By 5 points N/A #189603
You have to make sure that you are logged into your account correctly. If you are logged in, then you should try deleting your cookies, cache etc. You can use this link for deleting your caches, cookies. I think you should try logging in using the Google Chrome browser, if you are using another web browser. If it didn't solves your issue then i would like you to ask a Google drive expert.
Hope this helps
