Can’t TortoiseSVN 1.6.1.16129 on my computer.
I can't install TortoiseSVN 1.6.1.16129 on my PC. Whenever I try to install, it shows this error message. Can anyone help me on this issue? Thanks in advance.
Installing TortoiseSVN 1.6.1.16129 (32 bit)
An error occurred during the installation of assembly of component
{3C582984-7607-3E35-A337-D3D3270977351}.
HRESULT: 0x8007371B
Answered By 10 points N/A #131816
Hello Saraah,
In most cases, the error that you are getting occurs when there is a reboot that is pending and therefore no more actions can successfully be merged with the current set up. You will therefore need to do the following:
  • Reboot the computer.
  • After that you can try running the installation again.
In case you try the above and it fails, you will need to get the MSI clean up tool from the following link and then use it to get rid of any previous or failed TSVN installations that you might have performed on your computer that are leading to the error that you are getting right now
Carl
