Mike Waall
10 points
Posted on - 06/16/2012
Hello all.
I’m trying to update my Android software, but I’m unable to link with the Kies software. I always find an error message which states as given below. My OS is Win 7 34bit Ultimate.
What do you think is causing this error?
Can you give me some opinion and possible solution for this.
Help needed. Thanks in advance.
Error:
Cannot start service on the device.Please disconnect then reconnect the device.
Can’t update my Android software with Kies software.
You may have to update your software on your phone
Go to Home page on your phone
Locate about phone tab
Click on System updates
Select Update profile
It will take 2 mins. for your network to prepare the data services
Once the completion is finish click ok
Select Home
You may also need to uninstall the app.
Click on setting from the home page
Select applications
Scroll to Manage applications
From either download tab or running tab locate the app you downloaded for media player
Select uninstall
Once you uninstall you will want to reinstall.
These steps should help you out.
Make sure the device is not connected
Kies needs to be open
Select tools
Click on Install Device
After installing the computer needs to be rebooted
Once the computer is up and running you need to attach your device again
After windows acknowledge your device it will ask if you would like to reboot?
Reboot now( at this point you can reboot your phone as well its up to you)
Select connect your device
Remember to first end connection to Kies first before the USB!!
